Your explanatory style affects your life in ways you may not realize. It can minimize your stress response or exacerbate it. It can keep you feeling safe in socially dangerous situations, or endangered in relatively safe ones. It can motivate you when you're faced with challenges or leave you feeling vulnerable to them.
心理学家使用“解释性样式”一词来描述人们如何解释他们的生活事件。当发生一些事情时,我们的解释性风格是我们如何处理它的一部分,附上它的意义,并将其评估为我们生活中的威胁或挑战。这是一部分自言自语和部分自我感知,它以多种方式影响压力水平。
解释式的方面
有三个方面如何向自己解释一个情况。每个人都可以倾向于乐观或悲观:
稳定的与不稳定
This has to do with how you perceive thepermanenceof a situation. Is it changing across time or unchanging? Do you expect things to get better or worse, or stay exactly as they are for a long time? This can make a difference in how stressful something seems. If you are taking a stressful class in school, you at least know that the class will be over in a few months (whereas a stressful job may be something to deal with for years).
Global vs. Local
在你的生活中是一个压力源普遍(即,普遍存在)? Or is it specific to a part of your life? A good example of this is the feeling of having good or bad luck. If you feel yourself to be unlucky (bad luck pervades throughout your life), one negative experience may seem like an omen that more bad things are to come. Likewise, if you attribute a poor performance at work as being due to something global like a perceived inability to do the job well, one failure may seem like a sign of more failures to come. Someone who views one poor performance as being a sign of a bad day or lack of sleep—something more local and less global—will have an easier time shaking off one failure.
Internal vs. External
Do you see the cause of an event as within yourself (个性化) or outside yourself? If you are having a difficult day and you see it as being "your fault," you'll feel more stressed than if you see it as due to factors other than you. Likewise, when you are facing conflict with others, seeing the problem as being rooted in something that is "their problem" rather than "your fault" can help you to take things less personally and feel less hurt.
如果很多人对你有同样的投诉,那就有助于看看他们在说什么,评估是否有一些你可能想要改变的东西。但一般来说,它有助于知道,许多人的投诉可以与他们有更多的事情而不是与你有关。
Explanatory Style and Your Stress Levels
解释性款式影响我们如何感知世界,这可能影响我们对压力的经验以及我们对压力源的反应。如果我们有一个积极的解释性的风格,我们可能会感到挑战性的经历,因为积极的解释性风格可以最大限度地减少压力源的感知严重程度 - 他们看起来不是那么大的交易,将很快,不是我们的错,并不一定会复发。
Negative explanatory styles tend to create more stress in life and can make our stressors feel more threatening.
As you may have guessed,乐观主义者tend to have more positive explanatory styles—ones that minimize stressful situations as unstable, local, and external and take credit for positive experiences as being more stable, global, and internal.
Pessimists tend to see things in the opposite way, which can make stress seem like a bigger deal than it may need to be, and expands stressful feelings and even, research shows,抑郁症状。研究还表明,负面解释式风格的人可能会恢复更多的麻烦heart transplantsand other压力生活事件。
改变你的解释性风格
解释性款式可通过关注和练习来改变。你需要学习认识到自己的认知扭曲和实践cognitive restructuring techniquesto change those distortions. Doing so can lead to a change in explanatory styles from a negative explanatory style to a more positive one.
