Procrastination is one of those things that even the most well-organized and punctual fall victim to at some point or another. Think about the last time you found yourself watching television when you really should have been doing homework. While common, procrastination can have a detrimental impact on your life, including your grades.
那么学生和其他人可以做些什么来克服拖延,避免在最后一秒完成任务的压力,焦虑和性能不佳?
研究人员建议制定日程安排,仔细规划学术任务,提高时间管理技能是应对拖延的有效方法。
处理你的恐惧
豪华工作室/比尔雷泽尔/盖蒂图像
Fearis one factor that contributes to procrastination. This can involve a fear of failure, a fear of making mistakes, or even a fear of success.
心理学家Susan Krauss Whitbourne,Psychology Today贡献者和作者搜索履行,建议挑战您有错误的信念很重要。
如果你害怕成功,因为你暗中相信你不值得的,那么重要的是要意识到你的自我障碍可能会让你实现你的目标。通过解决让您入门的恐惧,您可以开始克服您的拖延习惯。
Break Projects Down Into More Manageable Segments
MoMo Productions / Getty Images
当你面对一个大型项目时,当你看看所涉及的工作量的工作量时,你可能会感到令人惊讶,恐吓,甚至无望。此时,在列表中取个单个项目并将其分解为一系列步骤。
If you need towrite a paperfor class, what steps do you need to follow? If you are planning a big family event, what are the things you need to do and what supplies do you need to obtain?
创建一个列表详细信息,详细介绍您需要通过以完成任务,您可以开始在个人“婴儿步骤”上。
认识到拖延的开始
As you start to tackle items on your list, pay attention to when thoughts of procrastination start to creep into your mind. If you find yourself thinking "I don't feel like doing this now" or "I'll have time to work on this later," then you need to recognize that you are about to procrastinate.
When you feel tempted to procrastinate, don't give in to the urge. Instead, force yourself to spend at least a few minutes working on the task. In many cases, you might find that it is easier to complete once you get started.
Eliminate Distractions
Sturti / getty图像
It's hard to get any real work done when you keep turning your attention to what's on television or you keep checking your friends' Facebook status updates.
Assign yourself a period of time during which you turn off all distractions—such as music, television, and social networking sites—and use that time to focus all of your attention on the task at hand.
