Tricyclic antidepressants (TCAs) are drugs used to treat depression, bipolar disorder, and other conditions such as chronic pain and insomnia. While newer classes of antidepressant have far fewer side effects, TCAs still have their place in the treatment of these and other disorders.
First introduced in the 1950s, tricyclic antidepressants are so-named because their molecular structure is composed of three rings of atoms.
How Tricyclic Antidepressants Work
一般来说,抑郁症是由化学引起的al imbalance in the brain which results in abnormal communications between nerve cells (neurons). The chemicals that deliver these messages are calledneurotransmitters. These chemical messages are relayed from one neuron to the next and, depending on the type of neurotransmitter involved, can influence how you feel and react.
三环类抗抑郁剂preventing the reabsorption of neurotransmitters calledserotoninand去甲肾上腺素. The body needs both of these to function normally. If there is too much of either, you may end up experiencing anxiety. If there is not enough, depression may ensue.
Because TCAs prevent the routine reabsorption (reuptake) of these neurotransmitters, there will be more freely circulating in the synaptic cleft between neurons in the brain. If you have depression, the restoration of the serotonin and norepinephrine levels can lead to an improvement in yoursymptoms.
Conditions Treated
Tricyclic antidepressants are used primarily to treat mood disorders but also have their place in the treatment of anxiety disorders, personality disorders, and neurological disorders. They are often used when other drugs are unable to provide relief.
Mood disordersoften treated with TCAs include:
- Bipolar disorder
- Dysthymia (persistent mild depression)
- Major depressive disorder (MDD)
Anxiety disorderssometimes treated with TCAs include:
- Body dysmorphic disorder (BDD), including eating disorders such as anorexia nervosa and bulimia nervosa
- Generalized anxiety disorder (GAD)
- Obsessive-compulsive disorder (OCD)
- Panic disorder (PD)
- Post-traumatic stress disorder (PTSD)
Neurological disorderssometimes treated with tricyclic TCAs include:
- Attention-deficit hyperactivity disorder (ADHD)
- Chronic pain
- Fibromyalgia
- Parkinson's disease
- Migraine
- Neuropathic pain
TCAs may also be used to treat insomnia, irritable bowel syndrome (IBS), interstitial cystitis, nocturnal enuresis (bedwetting), narcolepsy, and chronic hiccups.
Approved Medications
With tricyclic antidepressants, like other antidepressants, it will usually take between six to eight weeks before you feel any substantial improvement in your depression symptoms.
Some of the more commonly prescribed TCAs include:
- Anafranil (clomipramine)
- Ascendin (amoxapine)
- Elavil (amitriptyline)
- Norpramin (desipramine)
- Pamelor (nortriptyline)
- Sinequan (doxepin)
- Surmontil (trimipramine)
- Tofranil (imipramine)
- Vivactil (protriptyline)
Common Side Effects
While different TCAs have slightly different mechanisms of action, they share similar side effects. Many of these are associated with the effect the drugs have on the smooth muscles of the internal organs.
Common side effects include:
- Anxiety
- Blurred vision
- Constipation
- Dizziness
- Drowsiness
- Increased appetite
- Muscle twitches
- Nausea and vomiting
- Rapid or irregular heart rate
- Sexual dysfunction
- Sweating
- Weakness
- Weight gain
These side effects may be reduced if treatment is started with lower dosages and then gradually increased. While not strictly addictive per se, the long-term use of TCAs may lead to drug dependence.
TCAs are also a significant cause of fatal drug overdoses in the United States. Initial symptoms may include dry mouth, blurred vision, urinary retention, constipation, dizziness, vomiting, and hallucinations. If left untreated, an overdose may result in delirium, seizures, coma, cardiac arrest, and death.
Drug Interactions
Some of the side effects of tricyclic antidepressants may be intensified if taken with other drugs. In other cases, it can affect the bioavailability (concentration) of the drug in the bloodstream. As such, you should always advise your doctor about any substances you may be taking, including over-the-counter medications, herbal remedies, and recreational drugs.
Certain drugs are contraindicated for use with tricyclic antidepressants, including:
- Alcohol blocks the action of TCAs and should be avoided.
- Anticholinergic drugs used to treat urinary incontinence and COPD can cause intestinal paralysis if co-administered with a TCA.
- Clonidine, used to treat hypertension, can trigger a dangerous rise in blood pressure if used with a TCA.
- 肾上腺素用于治疗严重的过敏反应s can also trigger severe high blood pressure if used with a TCA.
- Monoamine oxidase (MAO) inhibitors, also used as antidepressants, can cause high fever, convulsions, and even death is coadministered with a TCA.
- Tagamet (cimetidine), used to reduce stomach acid, may increase the concentration of the TCA in your blood, further intensifying the drug side effects.
Tricyclic antidepressants can be effective in treating depression but may not work as well in some people as others. In some cases, the drug side effects may become intolerable and interfere with your very quality of life.
If you are suffering serious side effects, call your doctor immediately butdo not stop treatmentuntil your doctor tells you to. Stopping abruptly can cause symptoms of withdrawal, including nausea, fever, chills, headache, dizziness, lethargy, and vomiting.
Your doctor may be able to lower your dosage to where treatment is tolerable. If not, he or she would need to gradually taper the dose until you are able to safely stop.
