如果你有焦虑症,那么有时有用的情绪可以让你免于应对,甚至可能会破坏你的日常生活。焦虑症不仅仅是一个神经的案例。他们是疾病,通常与个人的生物化妆和生活经历有关,他们经常在家庭中运行。幸运的是,有许多药物可用于治疗焦虑症的症状。
Symptoms of Anxiety Disorders
通常,焦虑症突出的症状包括烦躁,不安,巨大,忧虑,快速或不规则心跳,胃痛或恶心,微弱和/或呼吸问题。这些症状因人和诊断焦虑症而异。
Types of Anxiety Disorders
There are a number of anxiety disorders, each with its own distinct features and symptoms. The most common are generalized anxiety disorder (GAD), social anxiety disorder (伤心)。恐慌症,恐惧症,强迫症(OCD)和创伤后应激障碍(PTSD.)。
Medications Used to Treat Anxiety Disorders
There are four major classes of medications that mental health professionals use to treat anxiety disorders:选择性血清素再摄取抑制剂(SSRIS),血清素 - 去甲肾上腺素再摄取抑制剂(SNRIS),苯二氮卓和tricyclic antidepressants(TCAS)。
使用用于焦虑症的药物被认为是安全有效的,并且在使用时甚至可能特别有用心理治疗.
选择性血清素再摄取抑制剂(SSRIS)
选择性血清素再摄取抑制剂通过引起更多的血清素在大脑中可用,从而提高了你的心情。SSRIS喜欢Prozac(氟西汀),Luvox(Fluvoxamine),paxil.(帕罗西汀)和zoloft.(sertraline) are good choices for any type of anxiety disorder. In general, side effects can include weight gain, sleeping difficulties (too much or too little) and sexual dysfunction. Many side effects go away within a couple weeks of beginning the medication, however, so give your body time to adjust.
Serotonin-Norepinephrine Reuptake Inhibitors (SNRIs)
血清素 - 去甲肾上腺素再摄取抑制剂与SSRI类似的工作,因为它们导致血清素的水平以及脑肾上腺素,在大脑中更高。实例是Cymbalta(Duloxetine),Effexor(venlafaxine)和Pristiq(Desvenlafaxine)。SNRIS被认为是SSRIS的有效性,特别是对于广泛性的焦虑症。副作用可能包括头痛,性功能障碍,失眠,胃部不适和增加的血压。
苯二氮卓
苯并二氮虫片或镇静剂通常用于很短的时间,以帮助您放松并摆脱焦虑可能伴随的肌肉紧张和其他身体症状。常见的苯二氮卓类药物包括Klonopin(clonazepam),Xanax(alprazolam), Valium (diazepam), and艾司芒(Lorazepam)。苯二氮卓类动物通常可以在短时间内缓解症状。
Different people respond differently to benzodiazepines. Some people may need to take them two or three times a day, and others only once a day, or on an as-needed basis. The dose is generally started at a low level and gradually raised until symptoms are diminished or removed. The dose will vary a great deal depending on the symptoms and your body chemistry. Benzodiazepines are sometimes given on an根据需要只是压力或焦虑袭击。
Use Caution With Benzodiazepines
Long-term use of benzodiazepines is not recommended because you can develop tolerance and/or dependence. Tolerance means that you need to take more of the medication in order for it to work. Dependence means that you develop withdrawal symptoms if you stop taking the medication. Some people abuse these medications in order to get high. Longer-acting medications such as Klonopin or Valium may produce milder withdrawal symptoms than short-acting medications like Xanax and Ativan.
You should abstain from alcohol when taking benzodiazepines because the interaction between benzodiazepines and alcohol can lead to serious and possibly life-threatening complications. Be sure to tell your doctor about other medications you are taking.
Be sure to talk with the doctor before discontinuing a benzodiazepine. A withdrawal reaction may occur if the treatment is stopped abruptly. Withdrawal symptoms may include anxiety, shakiness, headache, dizziness, sleeplessness, loss of appetite and/or seizures.
具有讽刺意味的是,许多这些症状类似于您可能寻求治疗的焦虑症状。为了避免这些症状,您的医生可能会逐渐逐渐逐渐变细。
Tricyclic Antidepressants (TCAs)
The last class of medications used for anxiety is tricyclic antidepressants. Because these medications were some of the first antidepressants developed, they can have severe side effects, including blurry vision, dry mouth, constipation, blood pressure drop when standing up and urinary difficulties. Examples of TCAs are Elavil (amitriptyline), Tofranil (imipramine) and (Pamelor) nortriptyline.
一定要将药物完全按照医生的规定服用药物。如果您有严重的副作用,请咨询您的医生,但没有医生批准,不要阻止您的药物,因为这可能导致严重的健康问题。
:max_bytes(150000):strip_icc()/Illo_SocialAnxiety-5a318bb4f9f44544928c364ec5b46ad3.png)
