Opiate addiction is a growing problem in the U.S. as evidenced by the 2015 outbreak of HIV in Indiana which was attributed to the abuse of the drugOxycontin。面对不断扩大的流行,prescription drug called Suboxone (buprenorphine + naloxone) is being increasingly used to treat opioid addiction.
If you or a loved one are struggling with substance use or addiction, contact theSubstance Abuse and Mental Health Services Administration (SAMHSA) National Helplineat1-800-662-4357for information on support and treatment facilities in your area.
For more mental health resources, see ourNational Helpline Database。
Understanding Opiates
Opiatesare a family of narcotic drug derived naturally or synthetically from the seed of the opium poppy plant (Papaver somniferum)。他们作为镇静剂抑制活动in the central nervous system, thereby reducing pain and inducing sleep.
Long-term opiate use can result in increased tolerance to the drug. When this happens, the user would need to increase the dose to achieve the same effect. This can cause an increasing dependence which we have come to know as anaddiction。In some cases, this can lead to accidental overdose and even death.
Some of the most commonly abused opiates include:
Treating Opioid Addiction With Suboxone
Suboxone is an oral prescription drug that was granted approval from the U.S. Food and Drug Administration in 2002 to treat opioid addiction. Prescribed as either a sublingual tablet or film, it contains two active drugs:
- Buprenorphine, a partial opioid antagonist, which provides relief from craving and withdrawal symptoms by blocking opiate receptors in the brain
- Naloxone, an opiate antagonist, which blocks the effects of the opiate drug itself
The combined use overcomes some of the shortcomings of the individual drugs. Buprenorphine, for example, has the potential to be addictive but is less so since the naloxone quashes the opiate effects.
Naloxone, by contrast, works in the background as a deterrent, only taking effect when opiates are injected into the system. When this happens, naloxone can inducewithdrawal symptomsincluding nausea, headache, sweating, restlessness, vomiting, and trembling.
Effectiveness
Suboxone has been found to be effective in that it reduces the cravings associated with long-term opiate use while providing deterrence to current use. Compared tomethadone, Suboxone is less addictive and faster acting (taking around a week to detoxify compared to weeks or even months with methadone).
Suboxone also seems to work better when used for longer periods of time. One study showed that opiate-dependent youth who used Suboxone for 12 weeks were more likely to remainabstinentcompared to counterparts who had only undergone two-week detox treatment.
How It's Prescribed
Suboxone is prescribed as part of a structured drug detoxification program and for maintenance therapy when needed. It is available as a generic (under the brand names Bunavail and Zubsolve) and offered in various formulations to ensure the gradual tapering off of use:
- 12 mg buprenorphine with 3 mg naloxone
- 8 mg buprenorphine with 2 mg naloxone
- 4 mg buprenorphine with 1 mg naloxone
- 2 mg buprenorphine with 0.5 mg naloxone
Treatment Plans
While approaches can vary depending on treatment centers, there are typically four steps to anySuboxone treatment plan:
- Intakewhich includes a medical and psychosocial evaluation, a urine drug screen, and blood tests to ensure that you can take the drug without harm
- Inductionto transition you from the opiates you are currently on to Suboxone with the aim of minimizing "cold turkey" withdrawal symptoms
- Stabilizationwhere Suboxone is adjusted to the lowest dose to suppress withdrawal symptoms to allow for eventual tapering off and discontinuation of treatment
- Maintenancefor those with severe addiction who may need on-going, medically supervised treatment and support (including attendance at aNarcotics Anonymousor non-step support group)
Considerations
Suboxone should not be used in persons with moderate to severe liver dysfunction as the can lead to a worsening of symptoms. Common side effects include headache, nausea, vomiting, excessive sweating, constipation, symptoms of withdrawal, insomnia, pain, and the accumulation of fluids in the legs (peripheral edema).
Suboxone does have the potential for misuse if injected. In such case, the relatively low dose of naloxone does not appear to mitigate the "high" achieved from the buprenorphine component. As such, Suboxone can only be prescribed under a doctor-supervised treatment or maintenance program.
Because opioid addiction is both a physical and psychological illness, treatment requires a multidisciplinary team able to address both of those needs. If you feel you could benefit from Suboxone, contact the hospitals or mental health agencies in your area for referrals to nearbyaddiction treatment centers。
