万博maxbetx官网登陆心理学闪存卡可以是一个非常有用的学习工具。当您试图记住重要事实,日期和概念时,它们可能特别有用。查看一些提示如何准备自己的闪存卡,其他地方您可能会发现有用的心理闪存卡,以及如何最好地使用这些的想法万博maxbetx官网登陆您的学习会议中的工具。
Make Your Own Psychology Flash Cards
使用闪存卡的最佳方法是制作自己的一组学习工具。这样,您可以将信息从类注释和所需读数中纳入其中。记住这一方便的经验法则 - 如果你的教师在课堂上谈论它,那么它大多可能正在考试。
Start by getting some blank index cards in whatever size works best for you. Index cards can be found in most general stores, office supply stores, or even at your university's bookstore. Don't be afraid to stock up on cards – you can always use the extras to make flash cards for later exams or even other classes.
在卡的一侧,写下您需要记住的一个事实。
您的闪存卡的潜在事实可能包括名称着名的心理学家, key terms, theories, and important dates in history.
只列出每张卡上的一个事实。
在卡的另一侧,写下答案。例如,在卡的一侧,您可能会写入:
A learning method that utilizes reinforcement and punishment to either strengthen or weaken responses.
在卡的另一侧,你会写:
您还可以以问题的形式提出您的事实,即“利用强化和惩罚的学习方法是什么,以加强或削弱反应?”
Go through your万博maxbetx官网登陆心理学笔记和读数并挑选您需要学习的信息。尽可能多的抽认卡,因为您需要充分覆盖材料。
How do you select the information to include in your flash cards? Start by looking at the bolded key terms in your textbook. Also check the summary section at the end of each chapter for a review of some of the key terms and concepts that you should probably include in your flash cards.
其他地方寻找闪存卡
If you are studying for a standardized test such as theAP心万博maxbetx官网登陆理学考试, then you might be interested in purchasing flash cards that are specifically designed for that test. For example,Barron的AP心理学万博maxbetx官网登陆闪存卡是一个研究工具,包括500张闪存卡,专注于AP心理学测试上可能出现的术语。万博maxbetx官网登陆
另一个寻找闪存卡的好地方是您自己的教科书补充材料。许多教科书也有在线网站,学生可以访问其他学习工具,包括交互式闪存卡。
最后,您可能会考虑形成一个研究组并共同努力创建自己的一组闪存卡。例如,让我们想象你和九个同学决定形成研究组。分配了该组的每个成员,并要求在密钥材料上创建一定数量的闪存卡。一旦大家都创建了分配的闪存卡,您可以将复制和分发给组成员,以便每个人都可以访问所有闪存卡。
使用您的闪光卡进行学习
Now that you've assembled a collection of flash cards, it's time to start studying. Start by mixing up the cards so that they are in a random order. Next, start working your way through the cards and see how well you do. How many answers do you know? If you end up with a very large stack of cards, you might want to break them up into smaller chunks, perhaps sorting them by topic or by book chapter.
非常适合家庭作业提示的专家,恩典弗莱明,有很多伟大的想法如何使用闪存卡来学习。一定要查看她对个人和团体学习的想法。
