大麻褪色的效果快速,但可以在体内检测到该目的几周,有时会更长。杂草的活性成分和击穿产品留在系统中的时间量可以在几小时到90天内,这取决于人们使用的大麻的频率或多少。
Although a number of states in the U.S. have active medical marijuana laws and recreational use of marijuana for adults over the age of 21 is legal in 11 states, Washington, DC, the Northern Mariana Islands, and Guam, the federal government continues to classify marijuana as a Schedule I controlled substance.
根据这一点药物滥用和心理健康服务管理局(Samhs万博手机客户端a)如果在18岁之前开始使用药物,大约1人使用大麻的10人将获得令人上瘾 - 这些率将上升到6中的1分。
FDA尚未获得批准medical marijuana对于任何医学指示,但它通常为慢性疼痛,恶心,艾滋病毒,多发性硬化症,青光眼和肠肠综合征(IBS)规定。
:max_bytes(150000):strip_icc()/how-long-does-marijuana-stay-in-the-system-67791_FINAL-5bbb7a5e4cedfd0026af0c22.png)
感受到效果需要多长时间?
大麻的影响可以从p的人不同erson. Some people may feel euphoric and relaxed while others feel anxious and paranoid. In other cases, people report feeling "dopey" and experience a loss of interest in activities or an inability to grasp concepts.
The chemical in marijuana that makes you feel "high" is tetrahydrocannabinol, also calledDelta-9-THC或简单地说。它以后迅速进入身体的血液吸烟大麻。
如果大麻口服而不是吸烟,则吸收到血液中需要更长的时间,通常从20分钟到一个小时一半,但这可以基于所采取的金额以及吸收和速率等生理因素而变化新陈代谢和排泄可以影响循环中的药物浓度。
效果can be far-ranging depending on the strain, method of consumption, and amount and can include the following:
- 口干
- Swollen eyelids
- Bloodshot eyes
- 令人愉快的身体感觉
- 增加胃口(“咀嚼”)
- Relaxation
- 刺激
- 扭曲的感知(瞄准,声音,时间,触摸)
- Loss of coordination
- 思维,记忆和解决问题的麻烦
- 增加心率
The short-term effects of marijuana on memory, learning, problem-solving, and coordination last for one to two hours, with some lingering effects for up to 24 hours.它已被证明损害你的驾驶据国家公路安全管理局称,绩效长达三个小时。
The effects of marijuana are also influenced by the terpene profiles of a given strain. For instance, citrus terpene profiles tend to be more stimulating, which may be the desired effect, or may contribute to someone feeling anxious.
重要的是要知道并非所有大麻都是平等的。与其他处方药不同,大麻产品没有标准化,质量,化妆和用量差异很大。
This variance may contribute to how quickly you feel the effects and what those effects are. THC can interact with alcohol, blood thinners, and抗焦虑药物,因此与医生讨论大麻使用非常重要。
大麻持续多久了?
大麻的半衰期是从血液中待代谢和消除的一半药需要多长时间。虽然有许多不同的大麻素,但THC是最多的药物测试。
THC快速分解并修饰成称为代谢物的分子。至少80种不同的代谢物是由THC形成的,并且可能对身体有自己的影响Endocannabinoid系统。这些代谢物储存在体脂中,并通过粪便和尿液逐渐消除。
一些THC代谢物消除了20小时的半衰期,而其他TH的半衰期是储存在体脂中,并且消除了10至13天的半衰期。
对于几乎完全消除的物质,需要五到六半。这就是为什么你看到一次性在五到八天后可能无法检测到的建议。
Blood and Saliva
因为大麻只留在血液中只有很短的时间,通常不使用大麻的血液测试。例外情况是汽车事故和一些路边清醒检查点。
Blood or saliva tests can show current intoxication. However, unlike血酒精浓度测试,它们并不表示醉酒程度或损伤程度。
头发
每日或接近每日大麻消费可能,但并非总是可通过头发测试可检测到三个月后。但是,头发测试不能可靠地检测不经常的大麻使用或确定使用的大麻的数量。
尿
大麻代谢物的尿液测试也只显示了最近的大麻使用,而不是目前的中毒或损伤。这是因为使用之间所需的时间和身体分解到尿液中消除的代谢物。由于许多雇主对吸毒具有零容差,因为大多数工作场所使用尿检来检测最近使用药物。
假阳性测试
Marijuana的工作场所测试可能需要首先用免疫测定测试筛选样品,称为发射或RIA。如果返回阳性结果,则使用气相色谱仪 - 质谱仪(GCMS)再次筛选样品,这更准确,因此误报是罕见的。
No known substances would cause a marijuana urine test to return a false positive.
At one time, ibuprofen (sold over-the-counter as Advil, Motrin, and Nuprin) would cause false marijuana positives. But today's tests have been adjusted to eliminate that problem.
在大麻是法律的地方,已知路边血液测试表现出在有法律上消费大麻的人中的一些误报,但在测试时没有积极陶醉。2016年报告详细说明了在路边测试口腔液体的比利时政策,发现它降低了这些类型的误报。
Factors That Affect Detection Time
The length of time marijuana remains in your body depends on many different factors, including frequency of use, body mass, metabolism, sex, and hydration levels.
使用频率
有一些证据表明,大麻仍然在身体中的时间长度受到该人使用大麻的频率,它们使用的程度,以及他们使用了多长时间。
使用大麻的人经常报告了自上次使用以来45天后的阳性药物测试结果,而在戒烟后使用更严重的人会报告过90天的积极测试。
在2017年研究中使用大麻进行头发试验的136人的研究中,存在五种大麻,THC,THC-OH,THC-COOH,CANABINOL和CANCABIDIOL的存在,以77%的重型用户和39%的39%存在轻便用户。
性别
女性经常以略微较慢的速率来代谢THC,因为它们往往具有比男性对应物更高的身体脂肪。
Metabolism
新陈代谢越快,这可能受年龄,身体活动和某些健康状况影响,大麻将退出您的身体。
Body Mass Index (BMI)
代谢物通常储存在你体内的脂肪细胞中,所以你的身体脂肪(或BMI)越高,你可能能够代谢和排泄大麻。
水合作用
当你脱水时,你将在身体中有更多的浓度。然而,淹没自己的水不会让你通过药物测试。相反,它会淡化它,你可能需要重试测试。
Smoking vs. Vaping vs. Edibles
使用方法也会影响检测时间。如果大麻被熏制或吐痰,那么身体的THC水平将比你摄取它的速度更快。edibles需要更长时间才能在身体中分解并留下您的系统。
如何从系统中获取大麻
许多雇主有一个工作场所药物政策,包括当前员工的随机药物测试常规测试所有新求职者。
如果您需要在短时间内就业或其他目的进行尿检,您最近熏制大麻,您可能会失败测试。如果您的使用常规或沉重,这尤其如此。
即使在大麻的娱乐使用已经合法化的状态下,您也可以解雇未能进行药物测试。
The only completely reliable way of passing the test is to stop smoking or ingesting marijuana or cannabis products.
虽然你会看到如何击败大麻药物测试的许多提示,但大多数都证明是城市传说。其中一些可疑技术包括以下内容。
Washing Your System Out
这种方法需要在测试前饮用大量的水或液体,然后尿了几次,然后服用维生素B-12将颜色添加回尿液。虽然这可能降低尿液中发现的THC的百分比,但稀释它,它不会完全消除代谢物。
有些人也会在测试前尝试锻炼,但这可以根据试验来锻炼,因为它可以根据期刊的一项研究,因为它可以将储存的THC从脂肪中释放到血液中药物A.n酒精依赖。
使用药物筛选剂
Some companies sell various substances and herbal teas that are allegedly capable of "cleaning" the body's system of traces of marijuana. There is little evidence that any of them actually work. The catch is that most of them have to be used over an extended period of time, during which the body will naturally eliminate THC anyway.
用测试篡改
This involves adding something to the urine to contaminate the sample. There are tales of using Visine, bleach, salt, or detergent to the urine sample, but these items are easily detected by the lab.
几种商业产品被出售为尿液测试掺杂剂,但没有100%万无一失。如果为它们运行单独的测试,则可以由实验室检测到所有这些。
Symptoms of Overdose
It is very difficult to physically overdose on marijuana because the lethal dose is so much higher than the effective dose. Very few marijuana overdoses have ever been reported. If someone you know has taken too much marijuana, and that is the only thing they have taken, an overdose is highly unlikely, but that doesn't mean that marijuana is not harmful.
心理困扰是可能的,因为判断的损害,这两者都可以导致可能损害自己和别人的危险行为。虽然罕见,人们在使用大麻以高剂量的情况下,人们可以体验毒性,尤其是以edibles的形式。症状可以包括:
- Heart arrhythmias
- 精神病或偏执狂(或加剧预先存在的心理健康状况)万博手机客户端
- Seizures
- 无法控制的呕吐
如果你或你爱的人有精神疾病的家族史,如果你在使用大麻之前咨询你的医生是有益的。
“集合和设置”的概念也很重要。由于占据了太多大麻的人可以体验感觉过载,最大限度地减少环境中的过度刺激投入可以帮助他们放松。有些人也比其他人更受大麻的影响。
得到帮助
您可能对医疗大麻处方进行处方,或者您可能希望在州级别娱乐使用的国家享用杂草或大麻怪异。有一种常见的看法,你不能在大麻上发展物理依赖性,但情况并非如此。心理依赖也是一项考虑因素。
If you discontinue marijuana after regular or heavy use, you may experience symptoms of withdrawal. Signs of marijuana withdrawal include:
- 胃口变化
- 进食后痉挛或恶心
- Cravings
- 消化问题
- 头痛
- 情绪波动
- 睡眠中断
- 体重增加
- 减肥
If you find that you can't handle symptoms of withdrawal without relapsing, you may be at risk for a物质使用障碍。不要害怕寻求精神卫生专业人员的专业支持。万博手机客户端
There are therapists who can help you understand your reasons for using. They also can help you determine how cannabis use is impacting your life, and how to develop a plan to stop using if that ends up being the best choice for you.
If you or a loved one are struggling with substance use or addiction, contact the药物滥用和心理健康服务管理局(Samhs万博手机客户端a)National Helpline在1-800-662-4357有关您所在地区的支持和治疗设施的信息。
For more mental health resources, see our国家助理数据库。
