五枪调查问卷是另一个short, self-administered test,旨在用于繁忙的主要医疗保健环境,以识别其早期阶段的酗酒。
The five-shot test is composed of two questions from the AUDIT test and three questions from the CAGE test and is designed to be a shortened version of the AUDIT test which can be administered quickly in emergency rooms or busy doctors' offices.
The questionnaire is short and easy to score, but it is not as accurate as other availablealcohol screening tests。five-shot探索ionnaire incorrectly identifies "normal" drinkers as hazardous drinkers 24 percent of the time.
Take the Five-Shot Questionnaire
Points for each answer are posted next to the answer.
1. How often do you have a drink containing alcohol?
(0.0) Never
(0.5) Monthly or less
(1.0) Two to four times a month
(1.5)每周两到三次
(2.0) Four or more times a week
2. How many drinks containing alcohol do you have on a typical day when you are drinking?
(0.0) 1 or 2
(0.5) 3 or 4
(1.0) 5 or 6
(1.5) 7 to 9
(2.0) 10 or more
3. Have people annoyed you by criticizing your drinking?
(0.0) No
(1.0) Yes
4. Have you ever felt bad or guilty about your drinking?
(0.0) No
(1.0) Yes
5. Have you ever had a drink first thing in the morning to steady your nerves or get rid of a hangover?
(0.0) No
(1.0) Yes
得分为2.5或更大表明可能的酒精滥用以及进一步评估的需要。联系您的医疗保健提供商。
短暂测验与极少的问题来确定患者的饮酒级别旨在在繁忙的初级保健办公室进行快速,初始评估,其中时间限制不允许更加冗长,详细的评估。
If the results of the short test indicate a drinking problem, the patient is usually given another appointment for a more detailed evaluation or referred to a specialist or a treatment program for further evaluation.
