Nothing can replace greatstudy skills但要练习好应试策略可以help improve your performance on psychology exams.这些技巧几乎适用于任何主题,所以开始研究你自己的应试方法,以确定哪些技巧最适合你。
每当你参加考试的时候,花一点时间来评估你做了什么工作效果很好,以及你将来如何再次运用这些技能。
Start by Looking Over the Test
:max_bytes(150000):strip_icc()/79253051-56a794665f9b58b7d0ebdf1a.jpg)
As soon as you receive the exam, spend at least a couple minutes looking it over. How many questions are there? What type of questions are on the test? In many cases, your万博maxbetx官网登陆tests will be a mix of different questions types. For example, the test might include a number of multiple-choice questions, a true-false section, and a few散文-style questions.
Understanding the format of the test will give you a better idea of how to budget your time.
Don't Skip Around
:max_bytes(150000):strip_icc()/79253229-56a794b53df78cf7729756e3.jpg)
有些人建议先从最简单的问题开始,然后再回到测试结束时完成困难的问题。虽然这一策略对一些学生可能有效,但它也使你更容易忘记回答跳过的问题。
Also, you'll lose more time by having to look back over your test and figure out which questions you didn't answer. Instead, try working your way through the exam in the order the questions are presented.
如果你发现自己struggling with a particular question, place a clear and obvious mark next to it and then move on to the next question. When you are finished with each section of the test, you can then quickly go back to the marked questions and try to come up with a response.
Use the Process of Elimination
:max_bytes(150000):strip_icc()/BF1078-001-56a794b53df78cf7729756f1.jpg)
一般来说,前几道选择题是最简单的,但不要让它导致过度自信。问题可能会变得越来越难,你进一步钻研考试,这是你应该开始采用心理应试策略称为消除过程。万博maxbetx官网登陆
When you encounter a question that you don't immediately know the answer to, start by carefully reading each possible answer. Then start ruling out the options that make the least sense. Even if you are completely baffled by the question, it is often possible to use common sense and your prior knowledge of psychological topics to determine a likely answer.
Remember that some multiple-choice tests include more than one answer that is technically correct. Your job is to select the answer that fully answers the question and is the "most correct" out of all the possible options.
仔细阅读每个问题
:max_bytes(150000):strip_icc()/103056286-56a794b73df78cf772975706.jpg)
It may sound like a bit of very obvious advice, but reading each question carefully is one of the most important test-taking strategies you can use on any psychology test. As you begin to read the question, you might immediately formulate a response before you've even finished reading the question.
如果你在完全阅读问题之前写下你的答案,你可能会错过重要的信息,甚至给出错误的回答。
