How to Study for the GRE Psychology Subject Test
woman thinking while taking exam
David Schaffer/Getty Images
If you are planning to apply to a psychology graduate program in the U.S., there is a strong chance that you will be required to take the GRE psychology subject test in order to be admitted to an accredited program. The test can be challenging, but there are plenty of things you can do to prepare for the test and get the scores you need to get admitted to a good psychology program.
Get the information you need to know about the GRE Psychology Subject Test. Discover what the GRE Psychology test is, what the test covers, what you need to do to prepare, and when the test is offered.
什么是GRE心理学科目测试?万博maxbetx官网登陆
GRE心理学测试万博maxbetx官网登陆是一个标准化的考试,通常被用作美国和其他英语国家的研究生课程招生过程的一部分。虽然测试是一个可选的单个主题部分的GRE,但如果考虑到申请,学生可以选择参加考试万博maxbetx官网登陆心理学研究生课程.
Not all psychology programs require the subject test. Some programs recommend that applicants take the psychology subject test, while others make it a mandatory part of the admissions process.
基本结构
在参加测试之前,您应该首先熟悉考试的基本结构以及测试所涵盖的内容。
  • Most editions of the GRE Psychology test contain approximately 205 multiple-choice questions.
  • Each question contains five different options and the test-taker must then select the option that best answers the question.
  • 您将有两个小时50分钟才能完成测试。
  • 心理学测试的所有版本都利用了最新版本的诊万博maxbetx官网登陆断和统计手册中使用的分类,诊断标准和术语。DSM-5.
  • 正确回答的问题数量被转换为总缩放分数。不减去不正确或未答复的问题,不会对得分产生影响。
  • The test may contain graphs, tables, and other material that serve as the basis for a number of questions.
  • Questions on the GRE psychology test are taken from core knowledge commonly taught in undergraduate-level psychology courses.
  • In addition to receiving an overall cumulative score, test-takers are also given six sub-scores: biological, cognitive, social, developmental, clinical and measurement/methodology/other.
  • While there are separate category questions and sub-score areas, they are not set aside and labeled specifically on the test. Questions from particular areas are instead distributed throughout the test.
GRE心理学测试涵盖的主题万博maxbetx官网登陆
The test covers three broad categories: Experimental and natural science (about 40 percent of the test), social science (about 43 percent), and general psychology (about 17 percent).
什么时候提供GRE心理学测试?万博maxbetx官网登陆
The GRE and subject tests are offered in April, September, and October for testing the United States and Puerto Rico. Check the official website to learn more about specific test dates.
注册测试
您可以注册在线或通过邮件进行测试。教育测试服务(ETE)建议您早期注册,以便在测试日期之前接收免费测试准备材料。
How to Prepare
In addition to reviewing notes and old tests from your undergraduate psychology courses, there are a number of different ways you can prepare for the GRE Psychology test. There are a number of different test prep books available to help students prepare for the psychology subject test. Visit your campus bookstore or an online book retailer to see what is available.
以下是在开始学习之前的一些建议:
  1. Start by taking a practice test before you start your test prep. This will give you a better idea of the content of the test and how much you need to do in order to prepare.
  2. Get a prep study booklet from a publisher such as Kaplan or Princeton Review, but do not restrict yourself to studying simply what is on the study guide. Only reviewing one or two study guides will not provide sufficient preparation for most students.
  3. 找到一个或两个良好的介绍性心理学书籍,花费相当多的时间熟悉每本书中的万博maxbetx官网登陆内容。
  4. After spending a considerable amount of time studying, take another practice test. By doing this, you will be able to get a better idea of which areas you are still weak in and what you need to focus on for the remainder of your prep.
还肯定会与您的心理学教授交谈。万博maxbetx官网登陆除了提供有用的学习提示, they may be able to help you organize a test prep study group.
ETS还offers a freePsychology Practice Book(以PDF格式)您可以下载并用于学习。
