Monocular Cues for Depth Perception
close up of an eye
Angela Lumsden / Moment Open / Getty Images
One way that we perceive depth in the world around us is through the use of what are known as monocular cues. These are clues that can be used for depth perception that involve using only one eye. If you try closing one eye, it might be more difficult to judge depth, but you're still able to detect how near or far objects are in relation to your position.
Depth perception allows us to perceive the world around us in three dimensions and to gauge the distance of objects from ourselves and from other objects. You can contrast monocular cues with binocular cues, which are those that require the use of both eyes.
These are some of the common monocular cues that we use to help perceive depth.
Relative Size
物体的相对尺寸用作深度感知的重要单手抄语。它的工作方式如下:如果两个对象大致相同,那么看起来最大的对象将被判断为最接近观察者。这适用于三维场景以及二维图像。在一张纸上的两个物体是相同的距离,但尺寸差异可以使较大的物体看起来更近,较小的物体越远。
Absolute Size and Familiar Size
Absolute size, or the actual size of an object, also contributes to the perception of depth. Smaller objects, even if we don't know exactly how big they are, will look farther away than a large object placed in the same spot.
Our familiarity with an object affects ourperceptionsof size and distance. While driving, your familiarity with the typical size of a car helps you determine how close or far away other vehicles on the road are from your location.
Elevation
An object position in relation to the horizon can also serve as a type of monocular cue. Objects located closer to the horizon tend to be perceived as farther away, while those that are farther from the horizon are usually seen as being closer.
Texture Gradient
Another essential monocular cue is the use of texture to gauge depth and distance. When you're looking at an object that extends into the distance, such as a grassy field, the texture becomes less and less apparent the farther it goes into the distance. As you look out over a scene, the objects in the foreground have a much more apparent texture. The asphalt of the road looks rough and bumpy. The vegetation in the field looks distinctive, and you can easily distinguish one plant from another.
随着现场消退到远处,这些文本ure cues become less and less apparent. You cannot detect every single tree on the mountain in the distance. Instead, the vegetation covering the mountains simply looks like an indistinct patch of green color. These texture differences serve as important monocular cues for gauging the depth of objects that are both near and far.
Motion Parallax
The perception of moving objects can also serve as a monocular cue for depth. As you're moving, objects that are closer seem to zoom by faster than do objects in the distance. When you're riding in a car, for example, the nearby telephone poles rush by much faster than the trees in the distance. This visual clue allows you to perceive the fast moving objects in the foreground as closer than the slower moving objects off in the distance.
Aerial Perspective
Objects that are farther away seem to be blurred or slightly hazy due to the atmosphere. As you look off into the horizon, closer objects seem more distinct while those in the distance might be obscured by dust, fog, or water vapor. Because objects in the distance tend to appear hazier, this cue tells us that blurry objects tend to be further away.
Linear Perspective
Parallel lines appear to meet as they travel into the distance. For example, the outer edges of a road seem to grow closer and closer until they appear to meet. The closer together the two lines are, the greater the distance will seem.
Overlap (or Interposition)
When one object overlaps another, the object that is partially obscured is perceived as being farther away. For example, if you see two figures standing in the distance and onefigure overlapsand occludes the other one, you will perceive the occluded figure as being behind the non-occluded one. This allows you to judge how objects are placed in relation to one another and contributes to your experience of depth in the world around you.
Shading and Lighting
The way light falls on objects and the amount of shading present can also be an important monocular cue. Objects that are darkened and obscured may appear further off in the distance than those that are brightly lit.
Accommodation
In order to focus on close-up objects, certain muscles in your eye contract, altering the shape of your lens. When looking at objects that are far away, these same muscles relax. This accommodation can serve as a monocular cue, even though we are often unaware of it.
How Monocular Cues Are Used
When perceiving the world around us, many of these monocular cues work together to contribute to our experience of depth.
The corner of a building looks larger and more textured, causing it to seem closer. Objects further down the street appear smaller, so we judge them as being farther away. The parallel lines of the highway appear progressively closer as they disappear in the distance, and the mountains in the distance seem fuzzy and indistinct.
All of these monocular cues contribute to our total experience of the scene, our perception of depth and distance, and our interpretation of our position in relation to other objects in the scene.
Monocular cues can play an important role in the detection of depth in the world around us. Unlike binocular cues, which involve the use of both eyes, monocular cues only require the use of one eye and can be presented in two dimensions. Because of this, many of these cues are used in art to create theillusionof depth in a two-dimensional space.
这个页面是有用吗?
Article Sources
  • Coon D, Mitterer JO. Introduction to Psychology: Gateways to Mind and Behavior. Belmont, CA: Wadsworth Cengage Learning; 2010.
  • Goldstein EB. Sensation and Perception. Belmont, CA: Wadsworth Cengage Learning; 2014.
