你怎么知道你是笨拙的吗?一段时间卑微的无论你有可能双极I或双极II紊乱(尽管被诊断为双极1,但您必须在您疾病的某些时候拥有一个完整的躁狂集。这个测验将帮助您确定您是否有过丑鼠。您可以在用医疗保健专业人员谈话时使用结果(即使您目前尚未被诊断患有双相障碍)。
测验是写成如果你目前经过ncing an episode, but you can also use it for past periods when you suspect hypomania was happening. If that's the case, consider a period of at least 4 days when some symptoms from each group were present every day, for most of the day.
Please note that this is not a formal diagnostic test. The results are intended for your use in talking to a doctor about your mental state.
Hypomania自检
在每个组中留下答案是“是”的问题数量。
第1组
- 您是否有能量和/或活动的不寻常增加?
- Do you feel abnormally happy, even though nothing in your life can account for it? The happiness may have begun with something special, but the happiness has lasted longer than normal.
- 你的心情异常吗?expans?
- 你没有真正的原因异常烦躁吗?
第2组
这些症状应代表与您的正常行为或经验的显着差异,以及其他人的观察。
- 你有感觉吗?grandiose,或者你的自尊高于正常情况?例如,你觉得你的任务或活动比你周围的所有其他人更好(当你通常不那么觉得)?
- Do you feel rested after just a few hours of sleep?
- Are you talking more than usual, or do you frequently feel like you absolutely必须保持谈话?
- 你有没有racing thoughts或者你是非常迅速的,从主题跳到主题(思想飞行)?
- Are you very easily distracted?
- 您是否身体焦躁不安,或者您是在冲动上投入项目(例如,凌晨3点左右排空所有壁橱,或者打电话给25位朋友邀请他们到下午的烧烤)?
- 你是否在没有思考可能的后果的情况下采取愚蠢的风险?或者你肆无忌惮地花钱吗?
第3组
- Are your behaviors causing严肃的生活中的困难(例如,关系或工作或学校的严重问题,你因他们而失去了工作等)?
- Are you having幻觉, or are youdelusional?
- Have you had to be hospitalized because of your symptoms?
笔记:Any是这个小组的答案规定了卑鄙的;考虑到这一点Bipolar Mania测验反而。
Scoring
在您对结果进行评分后,必须阅读其他重要因素(下面)至关重要。
第1组:
0-1是= 0分
2+是= 1点
第2组:
0-2是= 0分
3+ Yes = 1 point
Results
In general, 2 points are necessary to be diagnosed as having a hypomanic episode. However, the presence of a number of symptoms in any single group is an indication that you're in need of a mental health evaluation. Your doctor may still conclude that you have bipolar disorder.
其他可能性:
- 你可能会经历mania而不是丑陋。
- 您可能有一个混合的集。
- 您可能有另一种精神诊断。
其他Important Factors
您还必须考虑这些元素:
- Did your symptoms begin with the use of an illegal drug? If Yes, a diagnosis of hypomania can't be clearly confirmed, but you should still seek treatment immediately.
- 在发起抗抑郁药治疗后,您的症状是否开始?如果是,您仍然可能诊断出卑鄙,您还应该立即寻求治疗。
The psychiatric symptoms listed above should always be evaluated by a medical or mental health professional.
