血清血级别描述在你的血液在测试时间内给予药物治疗存在的量。用于治疗许多药物躁郁症有什么是所谓的小“治疗窗”,意味着一之间的区别治疗水平和有毒的水平可以在一些个体小。测试这些级别的某些药物的唯一方法是测试一个人的血清血药浓度。通过这样做,该窗口可以进行评估,并可以给予一定的药物的合适剂量。
什么是血清血药浓度?
血清是不包含凝血因子或血细胞的血液的液体部分。当医生检查血清血水平,他们通常检查锂水平在血液中,以确保正确的剂量给药。 If other medications are being taken, blood serum levels could be monitored regularly to ensure that lithium is not interfering with the medication. Specifically, the therapeutic range for lithium has been established at 0.6 - 1.2 mmol/L. Within this range, most people will respond to the drug without symptoms of毒性。
一些患者可能或多或少地锂敏感,因此需要进行跟踪,以减轻副作用和药物避免中毒。
药物,需要测试
除了锂,用于治疗双相性精神障碍一些药物需要血清血水平的测试。需要血清血检测水平的其他药物包括得理(卡马西平)和丙戊酸钠/ Depakene(丙戊酸钠,丙戊酸)。 Testing serum blood levels are usually done before medication is prescribed and follow-up can be as soon as one week up to every 6 months or more, depending on your physician's treatment strategy and how the medication is affecting your bipolar disorder. The test is usually performed by a professional phlebotomist in a lab or clinic setting. The blood is then separated into serum using a centrifuge. This separates the serum to be tested.
血清血水平和你的肾脏
长期锂盐治疗可导致慢性肾脏疾病。出于这个原因,血清血水平可以被监测以检查肾功能,而报错药物是躁郁症。 Other medications used for bipolar disorder may also cause kidney issues depending on how long and how frequently the drugs are used. A total serum protein test may be conducted to check organ function. Specifically, globulin and albumin levels will be checked.
高球蛋白或低白蛋白水平是值得关注的原因。
其他重要血清验血
你的医生可以测试你的血液血清水平钠,镁,胆固醇和可能的原因是血液中的个人资料修改等重要水平。血清血药浓度增加显示这些标记物的水平可能为拼写慢性疾病或精神病发作的风险增加。谈谈你的医生,如果你觉得血清血级别的测试可以帮助你评估你的健康。
