确定身体中可检测到多长时间的PCP取决于许多变量,包括使用哪种药物测试。PCP,又称天使灰尘,船,猪,爱情船,拆除液体,杀手杂草,火箭燃料,超级奖品,蜡,臭氧,可以检测到一些测试,但可以“可见”最多三个其他测试中的月份。
在系统中检测PCP的时间表也取决于每个个体的新陈代谢,体重,年龄,水合水平,身体活动,健康状况等因素,使得几乎不可能确定PCP将出现在药物上的精确时间测试。
PCP Drug Tests Timetable
以下是估计次数或检测窗口,在此期间可以通过各种测试方法检测PCP:
- Urine Test: One to two weeks
- Blood Test: 24小时
- Saliva Test:24-48小时
PCP,像许多人一样其他药物,可以用毛囊药物测试检测到长达90天。
某些非处方药和处方药y cause a false-positive result for phencyclidine (PCP) in some lab tests, namley:
- Dextromethorphan - Robitussin,咳嗽DM ER等,
- ibuprofen - Advil, Motril
- 丙酰胺 - 促罗拉尼,抗抑郁药,神经疼痛
- 二维氯胺 - Benadryl,抗组胺药
- doxylamine - unisom,抗组胺药,睡眠药物药物
- ketamine - anesthesia-like / may be used prior to colonoscopy
- 拉米氏嗪 - 抗癫痫
- tramadol - pain medication
- Desvenlafaxine - Pristiq,抗抑郁药
- Venlafaxine - Effexor,抗抑郁药
为什么剂量有所作为
在副作用方面,少量PCP之间存在显着差异。因此,了解PCP仍然在系统中的时间很重要。
Even at low dosages, PCP can cause a loss of coordination and numbness throughout your body. On large dosages of PCP, users have been known to become paranoid and disorganized. Some report hearing voices, acting strangely, or become aggressive or violent.
Harmful Side Effects
PCP可导致心率,呼吸速率,血压和体温增加。
Very large dosages of PCP taken orally can cause:
- 肾功能衰竭
- 肌肉刚性
- 心心律失常
- Seizures
- Death
由于PCP具有麻醉和痛苦的性质,因此在中毒时会发生严重伤害,因为用户可能不易掌握发生了发生的事情。
已发现长期使用PCP导致心理健康和认知问题。万博手机客户端
上瘾的性质
Some people who use PCP can become dependent upon the drug and develop classic symptoms of addiction such as not being able to get through the day without the drug and not being able to control how much of it that they use.
Phencyclidine users can also develop a tolerance to the drug which means they require larger and larger dosages of it to achieve the same effect, which can have negative health consequences as they take increased amounts of the drug.
Treatment
If you find yourself requiring larger amounts of PCP to reach the same "high" as you once experienced, you could be becoming dependent upon the drug and you may want to seek help in trying to quit.
如果您或亲人正在与物质使用或成瘾斗争,请联系Substance Abuse and Mental Health Services Administration (SAMHSA) National Helpline在1-800-662-4357for information on support and treatment facilities in your area.
For more mental health resources, see our国家助理数据库。
不像醇还有一些其他非法药物,没有药物可以通过减少药物的影响或减少试图戒烟的人来治疗PCP依赖性。行为治疗目前是PCP成瘾的唯一有效治疗。您可能需要进入住宅治疗计划,以便渴望和出现的任何物理或精神症状都可以管理。
