Heroin is an opiate processed from morphine extracted from the seed pods of certain varieties of poppy plants. It is an illegal andhighly addictive drugsometimes cut with other powder, including sugar, starch, powdered milk or quinine, to increase volume, which helps the person selling it make more money.
Between 2000 and 2014 the death rate from drug overdoses in the United States increased 137 percent and there was a 200 percent increase in the rate of overdose deaths involving opioid pain relievers and heroin, according to the Centers for Disease Control and Prevention.
Pure and Black Tar Heroin
In the United States today, you can buy two types of heroin: pure heroin and "black tar" heroin.
Pure heroin comes from South America and Southeast Asia and is a white powder with a bitter taste. Most of the heroin sold in the eastern United States isthis form of heroin.
Black tar heroincomes from Mexico and is sold mainly in the states west of the Mississippi River. It is typically sticky like roofing tar or hard like coal and gets its dark color from the processing, which leaves behind impurities.
Injected, Snorted and Smoked
A user injects, snorts or smokes heroin to get their fix. All methods deliver this drug to the brain quickly.
For black tar heroin, the user usually dissolves and dilutes, then injects it. Heroin in its powder form, on the other hand, can be more desirable tonew usersnot ready to begininjection drug usebecause you can snort it. You can smoke either kind.
How Heroin Affects the Brain
Once heroin enters your brain, the body converts it back to morphine and it binds to opioid receptors, located in many areas of your brain and body. The changes heroin causes in your brain causes its high risk for addiction and the chronic relapsing that may follow after treatment.
Long-term effects of heroin addiction on the brain include:
- tolerance - over time you will need more of the drug to achieve the same effect
- dependence - you need to use heroin do prevent withdrawal symptoms
- possible deterioration of the brain's white matter, which affects your ability to make decisions, regulate behavior and appropriately respond to stressful situations
Alcohol and Heroin Is a Deadly Combo
A person who overdoses is likely to be under the influence of more than one substance. In fact, the Drug Abuse Warning network warns that in overdose cases the patient has typically has an average of 2.7 drugs in their system.
A combination of alcohol and heroin is especially dangerous because both substances suppress your ability to breathe. If you can't breathe properly, the lack of oxygen can cause hypoxia, which can result in short- and long-term effects, including coma and permanent brain damage. Respiratory failure is the overwhelming cause of overdose deaths.
Effects of Heroin Treatment on Alcohol Consumption
Drinking alcohol is a suggested risk factor for heroin addiction. When an addict goes into treatment, either methadone maintenance treatment (MMT) or heroin-assisted treatment (HAT) their alcohol consumption goes down too, according to a study published in the journal Alcohol. Researchers found the HAT patients had a greater reduction in alcohol consumption.
